It is currently Thu Oct 22, 2026 12:42 pm
 Post subject: 2016 T22 in boat swap out
PostPosted: Tue Jun 07, 2016 7:12 am
Has anyone swapped it to xs650's
Just curious if anyone can confirm 650's fit no problem as their mounting depth looks to be a little deeper?
 Post subject: Re: 2016 T22 in boat swap out
PostPosted: Tue Jun 07, 2016 10:42 am
They are a direct replacement. I have swapped them out in my 2016 A24.
PostPosted: Tue Jun 07, 2016 12:32 pm
Sweet
I'll be powering mine with the ht 6 . 100w Mrs to each.
What are u powering to yours? R U happy with the results?
PostPosted: Wed Jun 08, 2016 12:07 pm
Using the same and yes i am very happy with them.
PostPosted: Wed Jun 08, 2016 12:39 pm
Have a brand new 16 t22 with stock ballast and 650 sumo's rear and front... works really well. still have space for storage when completely filled...
PostPosted: Wed Jun 08, 2016 12:53 pm
Fairly certain they're talking about speakers, not ballast bags.
PostPosted: Wed Jun 08, 2016 5:47 pm
LOL.
Hey if you swap out your in boats I'd buy a pair of them for my bow.
PostPosted: Thu Jun 09, 2016 6:59 am
I installed 650's in my 2015 T23. No issues with clearance and they are louder when powered correctly.
PostPosted: Thu Jun 09, 2016 11:52 am
To the guys that have switched them out...
Do you think it is worth the money if powering with the factory amps on a SP3 configuration?
PostPosted: Thu Jun 09, 2016 2:33 pm
I would do it. You can turn up your amp and the 650 will let you add more mid to them without distorting and separating from the cone. I left the factory speakers in the bow. I keep them turned down and unless you are cranking them they work fine, But I will replace them at some point.
