It is currently Mon Sep 15, 2025 4:18 am
[ 5 posts ] |
Author |
Bigguy4uk
Post subject: Speedometer/cruise control problem, help Posted: Mon Jun 06, 2016 8:28 pm |
Attempted to wakeboard last weekend and boat wasn't putting out a clean wake at normal speed I board at so assumed didn't have bags loaded right and had others on boat that wanted to surf so decided to give that a try. Attempted surfing at normal speed, 10-11 mph, and wake would not clean up so sped up to 13 ish before getting clean wake. At that point surf gate error, high speed warning and unable to surf. Assuming my speedometer or cruise control is not in calibration. Any help on resolving my issue? Once out of water I cleaned the power wheel, which did not seem to be dirty or blocked and plan on disconnecting batteries to reset but am looking for advice if this doesn't resolve my issue. Have not been able to put boat back in water yet.
Thanks in advance for the help.
Top |
IdahoAxis
Post subject: Re: Speedometer/cruise control problem, help Posted: Tue Jun 07, 2016 10:21 am |
You might try calibrating your speedo- download a GPS speedometer app for your smartphone and use that to check the accuracy of your speedo. Once you determine if it needs to be adjusted, use the speedometer calibration menu in the instruments setup menu. Mine was reading faster than actual from the factory.
Top |
steveA20
Post subject: Re: Speedometer/cruise control problem, help Posted: Tue Jun 07, 2016 10:57 am |
Team Axis |
Joined: Mon Oct 12, 2015 8:10 pm Posts: 480 Location: San Tan Valley, Arizona
Mine was also off by 4 mph from the factory. When speedo said 22 I was only going 18.
_________________ 2003 Sanger V210....SOLD 2005 MC X2....SOLD 2006 MC XSTAR....SOLD 2016 AXIS A20....SOLD 2018 AXIS T22....CURRENT
Top |
Bigguy4uk
Post subject: Re: Speedometer/cruise control problem, help Posted: Tue Jun 07, 2016 4:32 pm |
Thank you, I will give that a try
Top |
granddaddy55
Post subject: Re: Speedometer/cruise control problem, help Posted: Fri Jun 10, 2016 9:00 am |
Team Axis |
Wait a second, surfgate has that limit. He's not saying he's getting a difference between cruise and speedo like the 2014 speedometer and software recall as noted on forums on both sites axis and Malibu . 13 plus to clean up wake, it's another issue, axis wake cleans up to butter face st 9.8. This is a load in boat positioning problem, example if I'm on my full setup and multiple people want to sit on back seat, my wave won't form
I wake skate without jumping at 15 , eo you are up against the surfgate limit, 2014 it will simply retract at higher speeds I think
_________________ 14 A20, 850 rears with kinetic vents, front 950, stock plus wedge and 700 lead P5 53” Ahi, Brigade 4’10” goofy asym, LF Happy pill 4’8”, LF Catalyst Nomad skate, HL wakeboard with old Murry boots
Top |
[ 5 posts ] |
Users browsing this forum: Google [Bot] and 96 guests |
