It is currently Wed Oct 21, 2026 8:55 am
 Post subject: Stain on seat cushion
PostPosted: Mon Jun 06, 2016 8:51 pm
Sunshine it is. Thanks for all the advice.
 Post subject: Re: Stain on seat cushion
PostPosted: Tue Jun 07, 2016 5:51 am
dezul wrote:
Use it for the summer and see if it disappears. Don't use magic eraser on your vinyl. Ever!!! Unless it is just a small spot.
^this^
The magic erasers are abrasive and will remove the protective top coat off of the vinyl.
PostPosted: Fri Jun 10, 2016 9:12 am
Try goof off in a non conspicuous place. White first, then color, if it doesn't hurt the white it won't hurt the color
 Post subject: I cleaned mine, here are the details
PostPosted: Fri Jun 10, 2016 12:41 pm
I had a Hyperlite board do the same thing to my old boat Reversed Black HYPERLITE logo). They said it was a certain lot of their boards that had the problem, and they totally owned the problem and were outstanding in their support.
First they replaced the board with a new one.
Second they said that the best was to clean the seat really well and use the sun for a several days and that would probably fix it.
Third, they offered to reupholster my seat cushion, if that is what I wanted.
I cleaned it off by using a spray cleaner that was for mold and mildew (it has some bleach in it. I scrubbed it well, leaving it wet for a long time. After i rinsed it, I could still see it, but most others could not see it if they did not know it had been there. Then I put the seat in the sun for 2 days and it was completely gone!
I used some vinyl conditioner afterwards in case the cleaner was rough on the materiel. I later sold the boat to a nephew and the seat still looks great 4 years later. I did not want them to buy me a new seat as I thought it might not match. But Hyperlite totally stood behind their product and inspired me to buy more stuff from them because theya re great people.
WT
PostPosted: Sat Jun 11, 2016 8:39 am
How about challenging Hula Boat Care products? He says his cleaner works wonders (I use it)... he may send you a free sample to try? You would at least get a free koozie maybe.
PostPosted: Mon Jun 13, 2016 9:06 am
In a non conspicuous area try goof off and rag
