It is currently Fri Oct 23, 2026 2:07 am
 Post subject: Re: Wetsounds sub xxx v2
PostPosted: Sat Jun 04, 2016 9:31 am
alexandera wrote:
Arc Audio 15" is what I run... just upgrade; you'll be happier when Wiz Kalifa comes on your playlist... lol
Your sub is retarded deep and loud lol. Not many 15" subs in boats but Adam's is stupid clean and deep. Hydrotunes of Austin is awesome.
PostPosted: Sat Jun 04, 2016 2:45 pm
Before you spend the money on swapping things out. Have a good stereo shop with years of experience tune the amps with sound meters. I have a 2011 a22. I thought I would need to spend 1000 dollars to get what I wanted. $100 later and 2 hours of my time and it is everything I want. You taste could be much more than mine. Just a suggestion. May save some money.
PostPosted: Sat Jun 04, 2016 4:29 pm
Thanks for the replies, yes I am going to take it into my local shop to help them tune my 410 and SD4 as crazy stupid loud but not any bass. I think I need that adjusted and they going to look at the sub also and make some suggestions or possibly just a re-tune of the exile amp on there as well.
PostPosted: Sat Jun 04, 2016 9:13 pm
I had the same problem. Really loud but not bass. I still have factory mtx amps and sub. With wet sounds rev 8s on the tower. After audio shop tuned the amps. I can vibrate little waves off the hull when I turn it up. Open the compartment door and I can feel my chest vibrating from the bass. Not sure if you have the same problem but like I said worth a shot.
