It is currently Sun Sep 14, 2025 6:20 pm
 Post subject: Engine Fault - 2010 A22
PostPosted: Wed Jun 01, 2016 4:34 pm
This Memorial Day weekend we took the boat out and it kept throwing a engine fault code. It would go on and off and sometimes beep. I checked the oil and it was fine, I checked for anything obvious and saw nothing. The only dealer around me is backed up 2 months! I keep it regularly serviced, but don't know what it could be. Anyone else have this problem?
Additional Info:
I saw one of the vent hoses was ripped where it touched the engine block and probably just melted. I didn't have vent hose on me, so I took it off and used the metal duct tape as a temp fix. That shouldn't throw an engine fault code though.
 Post subject: Re: Engine Fault - 2010 A22
PostPosted: Thu Jun 02, 2016 9:49 am
Mine was doing the same thing last year and it ended up being grounds that were corroded took it to the dealer and they cleaned the battery grounds and the block grounds haven't had an issues since mines also a 2010 a22
PostPosted: Mon Jun 06, 2016 11:02 am
Anyone have any other suggestions? I cleaned the grounds (which were almost perfect) and code is still on. I even re tighten up the blower tube. Not sure what in the heck it is.
PostPosted: Mon Jun 06, 2016 12:52 pm
Press the two buttons at the same time and hold for 3 seconds. Scroll down to the "read fault code" or whatever its called option. Press select. If the fault code is present you will be able to see what it is. That would help worlds with troubleshooting.
PostPosted: Mon Jun 06, 2016 3:55 pm
I had no idea you could see what it is. Mine is a 2010, so I am not sure which two buttons you are referring to. I have a "info adjustment" rocker switch that can go up or down, but the up and down can't be pressed at the same time. Anywhere to find a 2010 A22 manual and maybe I can find it in there.
Users browsing this forum: No registered users and 121 guests
