It is currently Thu Jul 09, 2026 3:00 am
 Post subject: 2015 axis a22 bow ballast bag install question
PostPosted: Fri May 27, 2016 8:10 pm
Hi guys
I picked up my fly high 950 bow bag this afternoon.when I went to install it.it has 2 rear drain ports and 2 top ports.
When I looked at my pnp lines on the front of my 2015 axis a22.
Here is what I have facing the front of the boat.on the left side I had one short line.i connected that to my left rear drain.there was also a long full line.i cut that and connected that to my fill line.the other end of that I connected that to the overflow value.
Everything is working as it should.
My only question is my boat didn't have a second drain line.so my dealer told me to just cap the second drain line.
Does this seem correct?
Thanks bill
 Post subject: Re: 2015 axis a22 bow ballast bag install question
PostPosted: Sat May 28, 2016 5:42 pm
I had it out today on the lake and it seems to work fine.i just wanted to make sure I have it set up correctly?
I triple checked and I only could find one drain line in my bow on my 2015 a22.
PostPosted: Sat May 28, 2016 10:09 pm
My bow bag on my T23 seems to loose its prime sometimes...I'm going to empty it first before I empty the 900s in the rear lockers ...I think it may be a gravity thing.
2016 T23
