It is currently Thu Jul 09, 2026 12:21 am
 Post subject: Re: Options for pulling a prop
PostPosted: Fri May 27, 2016 7:09 am
6wakesurfers wrote:
Very cool tool. I don't change my prop unless I screw it up, which I haven't done in 10'years. However, I'm going to buy one of these and just change my prop for fun! I've been thinking of trying a new one anyway, I have the 2419 and occasionally struggle a little when we have ballasts/ PNP full and a larger crew on my t22 w/409. Recommendation? We surf primarily but wakeboard a little too.
No recommendation from me and I have the same motor and 2419. I use 4650lbs to over 5000lbs to surf plus wedge no problem. Wakeboard with around 2800-3000lbs and wedge no problem. Plus my A24 weighs a bit more and I'm sure I have 2-3 more batteries than most people.
PostPosted: Fri May 27, 2016 9:18 am
Are you at altitude?
PostPosted: Fri May 27, 2016 9:28 am
Same here with the 2249.. I am sea level to 1500 feet.
PostPosted: Fri May 27, 2016 3:52 pm
In Florida at about 150' above sea level. I'm normally pretty happy with performance but when I get a full tank and a bunch of my kids friends on board, I have to make 4 of them sit in bow.
Have wedge down, standard ballasts plus 750s in real lockers and under bow ( doesn't fill 100%). Guys at Tommy's don't think prop change will make dramatic difference. When loaded up, she planes perfectly at 3/4 tank of fuel. Seems like I'm just on the edge of having it right. I compensate by letting a lsome water out of the rear PNP at first.
I like the 2219 because I can run across lake at 39-40mph top end to get to our deep spot.
PostPosted: Sat May 28, 2016 1:33 pm
My tip? Get a C clamp puller, use a little grease when you put the new one on, and the first time you change it in a long time be prepared to really wail on it with a hammer.
All that said, this task is so easy you can do it underwater. :)
More details here: viewtopic.php?f=14&t=3573
PostPosted: Sun May 29, 2016 9:13 pm
To everyone who said just go buy the c clamp puller....they were absolutely right!!
4 hours later we finally got the old one off. It took building a puller from scratch in my wife's uncles metal fab shop.
2013 A22 // Mission Gate // 950 Arrow // 900 Rear Sumo's // Acme 2419
PostPosted: Mon May 30, 2016 5:11 am
I've been there myself. I learned quickly it's best to have a puller.
