It is currently Sun Nov 01, 2026 12:38 am
 Post subject: Coolers- yes/no and where to store?
PostPosted: Mon May 23, 2016 9:31 pm
Do you guys regularly carry a cooler on your boat?
Do you store it under seat or on floor?
Anyone use one of the high end coolers?
Just curious what you all do...
We just use a soft small cooler or none at all. I gues we are just too lazy to pack one
2015 T23
 Post subject: Re: Coolers- yes/no and where to store?
PostPosted: Mon May 23, 2016 9:39 pm
A24 has a recessed area for a 36-45qt cooler under the seat. I would buy a highend cooler if I was going to the moon but other than that a cheap cooler that holds ice for a full day in Texas heat is all I need. In my opinion, a Yeti on a wakeboat for a single day is a fad for the lifted 1/2 ton truck guys. There's at least 6 other cooler companies that do it just as good for 1/2 or 2/3's the price.
PostPosted: Tue May 24, 2016 4:43 am
I carry mine in floor of the T23.Image
PostPosted: Tue May 24, 2016 5:24 am
I alternate between a larger hard sided one and a smaller soft side one...depending on crew size. I also keep them under the port side dash instead of in the recessed area under the seat behind the driver. I like under the dash better because that seat back is hinged so you don't have to lift off a cushion and find a place to set it to get something from the cooler.
PostPosted: Tue May 24, 2016 5:25 am
Under the seat with my cheap igloo and it's pretty good. I just wish the seat had hinges or something to keep it out of the way while we are in the cooler. I hate killing my floor space tho so it stays in its place
PostPosted: Tue May 24, 2016 6:47 am
AO soft side cooler in the seat behind the driver. I have a large one and a small one for different crews/trips. AO has a Memorial Day sale going now I believe. I really like my coolers FWIW.
PostPosted: Tue May 24, 2016 7:12 am
Gibbs, what size cooler is that?
2015 T23
PostPosted: Tue May 24, 2016 8:13 am
I also use one of the AO coolers. I have the "stow and go".
PostPosted: Tue May 24, 2016 8:23 am
I use the igloo under the seat for water and all the kids drinks and then have this in the floor for the adults.
PostPosted: Tue May 24, 2016 10:50 am
Its a 45 yeti tundra.
