It is currently Sun Sep 14, 2025 6:25 pm
 Post subject: Surfgate
PostPosted: Sun May 08, 2016 3:19 pm
Got a surfgate hung and I've tried the reset any ideas? I'm out on the water
 Post subject: Re: Surfgate
PostPosted: Sun May 08, 2016 3:36 pm
Have you tried to surf the stuck side then switch to other side like a transfer and see if it will react to it?
PostPosted: Sun May 08, 2016 3:46 pm
Yes
PostPosted: Sun May 08, 2016 3:53 pm
Did you see if a breaker popped for that particular surfgate? Over here in AZ my dealer was having a heck of a time with a 2016 A22, surfgates kept tripping the 40 amp breakers so they were advised by Malibu to put in 60 amp breakers. Actuators and relays were good.
PostPosted: Sun May 08, 2016 5:21 pm
Where is the breaker?
PostPosted: Sun May 08, 2016 6:35 pm
That was a fun trip back to the dock[emoji107]Image
PostPosted: Sun May 08, 2016 7:18 pm
Probably not much help now. The same thing happened to me. I finally found that the small power cord in front port side of the engine compartment was loose and loosing connection. Good luck. It is labeled "surfgate"
PostPosted: Tue May 10, 2016 10:53 pm
Please let us know the resolution to this when you get it sorted.
PostPosted: Wed May 11, 2016 4:44 am
Did you try the "Service Surfgate" option? It should fully extend both gates then you can have it retract them. I had to do it a couple of times on mine when the "Recalibrate" option didn't work like it was suppose to.
PostPosted: Wed May 11, 2016 8:26 am
It didn't work. I took it back to the dealer they think it a bad actuator.
Users browsing this forum: No registered users and 120 guests
