It is currently Wed Feb 25, 2026 1:23 am
Post new topic Reply to topic  [ 93 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
 Post subject: Re: pull hard tanks and go bigger?
PostPosted: Sun May 08, 2016 11:29 am
Ok....you guys are very convincing! I'm going to remove mine also to get the most out of my 900s. Also, I'm tired of the gravity drain.
Any tips or concerns you guys may think of? I have a 2012 A22
PostPosted: Sun May 08, 2016 12:25 pm
I'm having trouble getting my wife onboard with pulling tanks. Take lots of photos please I have the same boat as you.
PostPosted: Mon May 09, 2016 10:43 pm
Just pull the rear sunpad doors completely off, I took the hinges and everything off then pulled the floor, remove all the hoses and fittings and the drain pump, then the tanks slide out fairly easy, the port tank I had to flex up a bit and I used a 2x4 in the front through the corner seat cushion hole and was able to pry the tank out pretty easy, the whole thing can be done in 2-3 hours with a couple of screwdrivers. I used one of the 90 deg fittings screwed into the bag and a short piece of hose for the drain.
PostPosted: Sat Jun 04, 2016 7:16 am
did my boat a few weeks ago with 1100# fly high bags and finally got to test it out last weekend on the water the bags full take up as much room as the pnp 750 bags did maybe even a bit less and far more weight and no more burping the air etc. I did not get any pics of them full yet but will post a few install pics soon
PostPosted: Sat Jun 04, 2016 1:35 pm
PostPosted: Sat Jun 04, 2016 2:25 pm
The rear starboard tank is smaller. Wonder what the weight difference between the 2 is.
PostPosted: Sun Jun 05, 2016 11:21 am
It's not too much difference probably just to offset the batteries and amps etc. But then you also have a driver offsetting the weight, I've never noticed the wave being off when wakeboarding. If it is off a little bit of lead or one of the brick sacs can take care of it or just drain port side a bit
PostPosted: Sat Jun 11, 2016 5:50 pm
FINALLY got this done on my A20. Got tanks and floors out without cutting. Removed sun pads as Walter did. I can't believe how much space this has freed up. Will be riding it tomorrow. Super pumped on it.
PostPosted: Fri Jul 08, 2016 9:06 pm
Doing this right now. Cant wait to test it out.
PostPosted: Fri Jul 15, 2016 3:31 pm
Walter and to others that have done this....how's it going? I currently have 900's I the back and I'm hoping that I don't loose weight buy removing the 250's. I assume that I have never really filled up my 900s to capacity so I should net out pretty even. Thought?
Users browsing this forum: Google Adsense [Bot] and 7 guests
