It is currently Mon Dec 15, 2025 11:29 pm
 Post subject: Spark Plugs, do I need to replace them?
PostPosted: Sun Apr 24, 2016 6:44 am
My 2011 A22 has 325hrs on it. I've checked the plugs before every season and they always look nearly new. These irirridum plugs are rated for 100k miles.
The boat runs flawless..... Should I change them just because?
 Post subject: Re: Spark Plugs, do I need to replace them?
PostPosted: Sun Apr 24, 2016 10:55 am
If you were driving a car at 100 MPH for 325 hours, it would only be 32,500 miles...
The engine wear is worse because of the crankshaft torque-loading of a boat, but the spark plug wear is not worse than a car.
PostPosted: Sun Apr 24, 2016 9:22 pm
I agree. The only concern I would have is with corrosion on the external section of the plug. If the plug shows signs of corrosion, replace it. I had an old Sea Ray that I changed the plugs on it shortly after I purchased it. Three out of the 6 plugs broke due to corrosion. I had to use a reverse screw extractor on it. I imagine the plugs haven't been changed in 10+ years.
Users browsing this forum: Google [Bot] and 57 guests
