It is currently Mon Nov 03, 2025 8:18 pm
 Post subject: Re: Fuel Tank Frustrations
PostPosted: Wed Oct 28, 2015 7:34 pm
Same here... I have a 15 T22 that I've run "empty" per the gauge. Filled it up with only 36 gallons. I even went back and checked the specs to see what size tank it had.... says 42 gallons.
2015 T22
PostPosted: Thu Oct 29, 2015 11:57 am
Not sure if I had posted this before but my fuel gauge is off a bit too. I show full for a very long time and then when I am about 1/4 full my gauge shows 1/2. I am sure that the sending unit location is probably the reason for the discrepancy. With that said, I am able to run my gauge down til it shows empty and I am still able to start my boat. I have twice filled up my boat with 44 gallons (and it is a 46 gallon tank) and my gauge showed empty. I had no issues starting it when it was very empty either.
Hopefully you do not have anymore issues... but at least now you know a bit more about your capabilities, and when you get very low on fuel and you are not near gas, you now know not to shut down your engine.
PostPosted: Sat Apr 23, 2016 1:35 pm
The tow of shame. Just plane ran out of gas while pulling surfers. Seems like it went from 1/4 tank bar length to stalling. Little John boat towed me all the way home. Now I know exactly when I need to fill her up.Image
Users browsing this forum: Majestic-12 [Bot] and 52 guests
