It is currently Sat Sep 26, 2026 11:26 pm
 Post subject: Re: Tower lower assist?
PostPosted: Fri Apr 15, 2016 3:14 am
Hi there , I had to lower tower all the time to put in boat shed a real pain . So I set up A gas strut system & worked very well , can raise & lower with one hand .
PostPosted: Fri Apr 15, 2016 8:07 am
I like it!
Only recommendation I could give would be to go with stainless struts.
PostPosted: Fri Apr 15, 2016 8:17 am
Very nice setup! I have never lowered my tower thankfully but if I had to I would do this!
PostPosted: Fri Apr 15, 2016 3:28 pm
look at that.. someone already a step ahead.
PostPosted: Sat Apr 16, 2016 7:36 am
Well, no sh!t.... how about that set up??? It's on dawg.
PostPosted: Sat Apr 16, 2016 8:07 pm
Can you post some more detailed pictures and tell us what shock you used? Looks great
PostPosted: Sun Apr 17, 2016 11:48 pm
I'd love to see a solution like this on the newer style tower. I put mine down for the first time today and that thing is very heavy with the bimini and one pair of Rev8s.
PostPosted: Mon Apr 18, 2016 4:58 am
Have some other photos , the gas strut is from a Caterpiller skid steer loader, Can get from any CAT dealer. The top mount is the Bimini mount rings , orded 2 from boat dealer & made up the bottom mount block with a threaded ball joint & bolted to tower. Should be Abel to set up a similar set up for the 2015/16 tower .
PostPosted: Mon Apr 18, 2016 9:29 am
PeterMcRae
Can you provide the CAT part # for the struts?
PostPosted: Tue Apr 19, 2016 4:42 am
The gas strut part no is 153-2683 . I haven't got a part no for the lower ball joint that I used , was an old part sitting around the shed.
