It is currently Sun Sep 27, 2026 8:27 pm
 Post subject: Closed cooling
PostPosted: Fri Feb 26, 2016 6:42 pm
Has anyone thought about converting or have converted their cooling system to a closed loop system? If you have what was involved in successfully doing this? I'm thinking this would eliminate the need for winterizing.
 Post subject: Re: Closed cooling
PostPosted: Fri Feb 26, 2016 8:00 pm
I'm not engine savvy, but I had to winterize my closed cooling engine. I have the corvette engine. They but said the manifold still needs drained??? I'm not sure if that was the correct part.
2014 A24 w/ LS3
PostPosted: Fri Feb 26, 2016 8:35 pm
Pretty sure the cost would make it not a viable option unless you want it for salt water as well.
PostPosted: Sat Feb 27, 2016 6:04 am
mine has the closed system but as jdiaz said certain parts still get water cooled, exhaust manifold and the v drive and trans, so you still do a basic winterization
PostPosted: Sat Feb 27, 2016 6:54 pm
Thanks for the info guys. I'm filing that idea in the circular file.
PostPosted: Tue Mar 08, 2016 5:28 pm
It's not a terrible question, and a closed cooled boat can usually be drained much more quickly than a raw water cooled boat. Yes, you still have to drain, but it can be as easy as pulling the vdrive plug and two manifold plugs, depending on your setup.
here's a good DIY thread for an indmar conversion: http://www.themalibucrew.com/index.php? ... onversion/ Pretty sure you can buy a turnkey kit with all hoses and everything for a crusader (PCM), but I can't find the link. IIRC the cost of the kit was like $2k.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 44 guests
