It is currently Tue Nov 10, 2026 7:35 am
 Post subject: Re: Basic Battery Questions
PostPosted: Wed Feb 17, 2016 10:41 am
Factory mount on my 15' A24 is just to the rear of the amps on the rack, on the outboard wall. Prosport mariner 20 I believe.
PostPosted: Wed Feb 17, 2016 10:48 am
Factory is Prosport 12. People mount them everywhere, amp rack, inside wall by Perko switch, even the wall behind the bow seat.
PostPosted: Wed Feb 17, 2016 8:24 pm
Now if I used a starter battery and then had a true deep cycle battery as battery 2, could I use the deep cycle to start boat if the starter battery failed for some reason?
I see some people use the XS Power xs3000 as their deep cycle battery to power their stereo system
2015 T23
PostPosted: Thu Feb 18, 2016 7:33 am
I think you are trying to over do it. The dual battery system that comes from Axis works great and I have never been stuck because of a battery. If you plan on jamming the radio for a long time, just switch the battery to one or the other. No need to change things up unless you just want to spend money for the fun of it.
2014 A24 w/ LS3
PostPosted: Thu Feb 18, 2016 8:15 am
I agree we have never had a problem. We sit with the radio on for hours sometimes with the standard system with no issues.
PostPosted: Mon May 02, 2016 6:28 pm
Thanks for everyone's input. I added the onboard charger and works great. Great piece of mind.
2015 T23
PostPosted: Mon Jan 02, 2017 1:10 am
I run about 3200W so I'm cautious on the water when it comes to batteries. I run a starter battery and a Kinetik power cell for the audio on a Perko. I have a Noco Genius dual bank onboard charger. I've left out connected for WEEKS. I trust it immensely (as you can tell). I've had the promariner20. The Noco is hands down better. It can charge different types of batteries on each bank. The 20 can't.
https://www.amazon.com/NOCO-GEN2-Waterp ... B003JSJS5I
