It is currently Wed Jul 22, 2026 10:14 pm
 Post subject: 2015 Underwater Lights
PostPosted: Sat Dec 26, 2015 9:29 am
Anyone separated their underwater lighting from the interior lighting yet? If you are and haven't chased wires yet, they are spliced together with the interior lighting circuit somewhere. I plan on running an independent circuit to the accessory switch so they can be independently operated. Helps minimize the bugs!!!
Anyone else interested in this project?
 Post subject: Re: 2015 Underwater Lights
PostPosted: Sat Dec 26, 2015 9:59 am
I am wanting to do it as well when i put my radio onto a switch
PostPosted: Sat Dec 26, 2015 11:21 am
I wired mine a separate switch.. just ran new wires to the rear.
PostPosted: Sun Dec 27, 2015 9:20 am
r33pwrd -- did you simply disconnect the quick connect and splice in right there or what... if you don't mine sharing.
PostPosted: Sun Dec 27, 2015 8:00 pm
I did not have factory install underwater lights so I ran all new wiring and just grabbed power off somewhere (don't remeber where) I did the lifeform 9.
PostPosted: Sun Apr 03, 2016 8:45 am
Alright folks, I just completed this project yesterday... below is a summary of the process in case anyone is interested:
Purchased 30' of 14AWG stranded wire
Fished and strapped new wire from dash around to port locker
Disconnected OEM lights at waterproof automotive connections
Ordered OEM water proof connections from Amazon ($7 ea)
Made up to wire laterals with male OEM connectors on one end and T-tap splice connections on the other
Spliced into new wire and made final connections at lights
Made up connection at helm
Done.
Since I had the wire there, I went ahead and added a 12" strip of LEDs behind the starboard and port air grills... lol
No more bugs while partying in the water at night.
