It is currently Mon Sep 15, 2025 8:47 am
[ 4 posts ] |
Author |
schwarzfj
Post subject: Board rack - rubber strip Posted: Tue Sep 08, 2015 4:58 am |
Newbie |
Have a 2014 A20 with the stock board racks. The rubber strips constantly are coming out. Has anyone else experienced this and what solution did you use to prevent this from happening? Glue??
Top |
jdiaz78
Post subject: Re: Board rack - rubber strip Posted: Tue Sep 08, 2015 7:10 am |
Team Axis |
Joined: Sat Sep 06, 2014 11:41 am Posts: 86 Location: Kansas City
Having the same problem. I thinking I'm going to try some glue also.
_________________ 2014 A24 w/ LS3
Top |
Tnbrooks01
Post subject: Re: Board rack - rubber strip Posted: Tue Sep 08, 2015 1:11 pm |
Use a small amount of "gorilla glue" under the strip.
Emphasis on small amount as the glue will expand as it dries.
If you do put too much on there the excess glue is easily removed by cutting with a razor blade.
Top |
schwarzfj
Post subject: Re: Board rack - rubber strip Posted: Thu Sep 10, 2015 10:21 am |
Newbie |
Thanks for the tip, I'll try the glue. Does anyone know the mgf of the board rack and where a reasonably priced rubber replacement can be purchased. Thanks in advance.
Top |
[ 4 posts ] |
Users browsing this forum: No registered users and 129 guests |
