It is currently Mon Dec 01, 2025 8:28 pm
 Post subject: Vinyl Clean and Conditioning
PostPosted: Sun Aug 09, 2015 6:28 pm
We have read several blogs and forums discussing the proper approach to cleaning and maintaining vinyl surfaces and thought we would share a few ideas.
Some of the discussions talked about using magic eraser, aggressive cleaners, mild cleaners, multi-surface cleaners, using scrub brushes, cloth and more.
We subscribe to the theory that you start with warm water and a mild soap. I have used a terry cloth towel for this first step on several occasions. And, this is what the marine vinyl manufacturers recommend - at least as a first approach. Always test in an inconspicuous area first, perfect your technique and then replicate across a wider area.
And, avoid anything with an abrasive surface. Leave as much material there for the long haul.
When mild soap and warm water is not enough, we recommend that you use a vinyl cleaner and conditioner. There are many different cleaners on the market but cleaning is only the half of it. You must protect the surface. At Hula we offer a vinyl cleaner and conditioner or at least recommend that you use a product that is designed for marine grade vinyl and always follow-up with a conditioner. Critical step that is overlooked far to often. You can learn more at http://products.hulaboatcare.com/?page_id=1405
What Rocks Your Boat?
 Post subject: Re: Vinyl Clean and Conditioning
PostPosted: Sun Aug 30, 2015 8:10 am
I use all of your products with the exception of Wipe Out... only because the wife says it has too much of a chemical smell.
If you could get that squared away, you may attract additional customers.
All of your products rock... especially your waxes.
PostPosted: Sun Aug 30, 2015 10:58 am
Yep the waxes are the best!
PostPosted: Sat Sep 12, 2015 10:09 am
Just went over mine with the hang ten cleaner and an orbital polisher, what a difference, I had some pretty good spots and a few board marks and it's all gone now, and for reference the boat is 5 years old
PostPosted: Sat Sep 19, 2015 8:59 am
Great Walter, now I need to clean my trailer... LOL
