It is currently Fri Apr 17, 2026 10:30 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Surf gate
PostPosted: Fri Aug 28, 2015 10:39 pm
Platform cut down & glassed back together
File comment: Cutdown platform
PostPosted: Fri Aug 28, 2015 11:06 pm
Finished platform
PostPosted: Fri Aug 28, 2015 11:08 pm
Carbonfiber surf gates finished
PostPosted: Fri Aug 28, 2015 11:11 pm
Billet alloy hinges.
PostPosted: Fri Aug 28, 2015 11:15 pm
PeterMcRae wrote:
Hi there , l have a 2011 a22 & have spent the last 12 months retro fitting surf gates . Live in Melbourne Australia , had to order lenco 102 actuators from USA , Boat dealer would not sell any parts at all without HIN numbers to match the surf gate year model 2014. Started by cutting down swim platform ,made surf gate out of marine ply then rapped them with carbon fibre . Put 2 extra layers of fibre glass inside rear of hull . Tried to order the hinges from dealer & no hope, made hinges out of blocks of alloy in two parts & bolts for hinge points. Will try & down load some photos , need daughters help.
Looking forward to the photos. I'm curious if the rear of the hull even changed, some are reporting that Malibu was just saying it did but then changed nothing.
PostPosted: Fri Aug 28, 2015 11:18 pm
Mounting hinges
PostPosted: Fri Aug 28, 2015 11:21 pm
Mounting gates
PostPosted: Fri Aug 28, 2015 11:23 pm
Mounted up & looking good
PostPosted: Fri Aug 28, 2015 11:36 pm
Put 2 extra layers of glass around actuator & hinge points. when drilling into hull found it to be over 3/4 inch thick ,had to order longer button head bolts. Do not believe that the hull is any different all the way up to 2015 for A22 .
PostPosted: Fri Aug 28, 2015 11:58 pm
Peter, this is looking like DIY project of the year.
I wonder if the worry about hull damage is not really a concern. People throw trim tabs on boats all the time and I would think those would have higher pressure concerns due to them being lower in the water and used at higher speeds.
Users browsing this forum: Google [Bot] and 5 guests
