It is currently Mon Sep 28, 2026 3:12 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Cooler
PostPosted: Fri Aug 21, 2015 8:48 am
I am having the same issue with the lid hitting on the back however I have the added problem of the lid ialso hitting the rear seat cushion. Not a well thought out design for a critical piece of equipment.
PostPosted: Fri Aug 21, 2015 8:56 am
Just unscrew the hinges so the lid can slide out and up.
PostPosted: Fri Aug 21, 2015 1:45 pm
So glad the A24 doesn't have that this issue. Would drive me nuts.
PostPosted: Sat Aug 22, 2015 10:17 am
AO soft coolers. They are awesome. Stay cold all.day and don't leak a bit. I have two that fit under the seat on the left side. They fit perfectly and hold a bunch of stuff. They are on Their website and are in the boat cooler section. They are about $70 but worth every penny.
PostPosted: Sun Aug 23, 2015 9:44 am
Get a Yeti and be done with it. You won't regret it! I can hook you up on one too. ;)
PostPosted: Sun Aug 23, 2015 10:25 am
I have three Yeti's. They are good coolers but very pricey.
PostPosted: Tue Aug 25, 2015 10:14 am
Hey guys new to the forum and Axis. Traded in my 2011 Tige R20 for a 2015 Axis A22. I was shocked when the cooler wouldn't open. Didn't even think to try that when I was checking out the boat. I like the idea of removing the hinges and will give that a shot.
Just wanted to share what we did our first time out. Flip the cooler around so it opens toward the center of the boat. A bit goofy but it worked.
PostPosted: Tue Aug 25, 2015 10:50 am
It's funny you mentioned that. Immediately after I took the hinges off I noticed that turning it around backwards would also help free the lid.
PostPosted: Fri Aug 28, 2015 10:16 am
It would be "cooler" if you could some home snap the cooler lid to the seat bottom so they both open with one hand!
PostPosted: Thu Feb 25, 2016 10:22 pm
Noticed the same thing last weekend when checking out the new A22. Obviously they haven't addressed the issue in the 2016's. I have the same problem as one of the other members where not only does my lid not open without having to pull the cooler out a bit but I have to remove both seat cushions because about 1in of the cooler sits under the back most corner cushion. Why offer a pricy factory option if it isn't well thought out/designed? Or at the very least let you open the dang thing?? SMH
Toy Store:
2016 A22 Green/White
2009 Built Jeep Wrangler
1978 Bandit Trans-Am
