It is currently Sat Nov 08, 2025 10:26 pm
 Post subject: HELP diagnose SERVICE ENGINE issue!!!
PostPosted: Fri Aug 21, 2015 7:50 pm
I just got boat back from it's first service and on way back to the dock cruising full out for a few minutes I get a SERVICE ENGINE message and rpm's drop down. I noticed coolant was at 190 degrees.
My thoughts are the coolant is low, I will check in am when it is cool and fill if needed.
Any other ideas?
No fault codes were thrown on the gauge screen when I checked that.
Would low coolant cause this to happen with no fault codes?
Please advise,
I have people coming from out of town on Sunday to use the boat and now this... bummer.
Jason
 Post subject: Re: HELP diagnose SERVICE ENGINE issue!!!
PostPosted: Fri Aug 21, 2015 8:08 pm
You need to be quick to get the fault code. Do you have a freshwater cooled motor with a closed cooling system? With a brand new boat why would the coolant be low? I think its much more likely that you have a plugged cooling system but most of us are raw water cooled so you may not get a ton of response here.
PostPosted: Sat Aug 22, 2015 11:47 am
I topped the coolant off this morning and it didn't really take much at all so that might not be the issue. However both times yesterday when I was having the issues it was while running full out which I hardly ever do. about 5500rpm's. I did notice in the manual it mentioned max range should be about 5200 I think... Not sure if that was the issue. (it's a Monsoon 350)
I took it out this morning and simulated surfing for a while with no issues. So I guess I will be good to go tomorrow and keep a close eye on things.
Jason
PostPosted: Sat Aug 22, 2015 3:37 pm
Some 2015 350 owners needed to update their ECM's due to exhaust temps being set incorrectly.
PostPosted: Sat Aug 22, 2015 7:20 pm
That's the boats way of telling you to take it easy lol
PostPosted: Sun Aug 23, 2015 9:25 pm
Need to have the software flashed. Our dealer has had to do this to every 350 monsoon they have received this year. Something to do with exhaust temps reading incorrectly.
