It is currently Wed Mar 18, 2026 6:43 pm
 Post subject: T23 hard turning left when surfing
PostPosted: Wed Aug 12, 2015 12:37 pm
My setup is stock full-750 PNP rear - front PNP full - wedge deployed - 11mph 4-6 people in the boat. 1235 prop. When surfing regular the boat is very hard to turn to the left. When pulling a goofy surfer the boat turns fine both directions. Has anyone else experienced this?
 Post subject: Re: T23 hard turning left when surfing
PostPosted: Wed Aug 12, 2015 1:25 pm
Mine does it too, pretty sure it has to do with the prop rotation. You can adjust the rudder tab and it will help a little bit.
PostPosted: Wed Aug 12, 2015 8:09 pm
Thanks For the reply Robert. I figured it was but just needed to make sure.
PostPosted: Mon Aug 17, 2015 4:56 am
It's because the gate comes out. When surfing left side/regular, the gate comes out on the right, facilitating a right turn and making a left turn harder. When surfing right side/goofy, the gate comes out on the left, facilitating a left turn and making a right turn harder. Bottom line, turn away from the surf side when going back to get a fallen surfer.
Maybe the prop rotation makes it a little more noticeable on one side, but I've found if you keep the speed down to where the gate doesn't come out, it's much better.
