It is currently Thu Oct 22, 2026 1:23 pm
 Post subject: T23 Engine Diver wall issues
PostPosted: Wed Jul 29, 2015 2:10 pm
Ok guys, I'm having a bit of an issue and wondering if anyone else is. Here is my dilemma, I currently have the Sumo 900's in my rear lockers of my T23. first problem I was having is it was pushing in on the walls and they were popping off the tracks, so I went online and bought the wake makers diver wall kit. That solved the issue of it happing all the time, but now they seem to still pop off every once and a while. I have shifted the bags and everything, all with no constant luck. Question is, has anyone reinforced the bottom track on there boat?? That seems to be where the issue is. Any help is appreciated.
 Post subject: Re: T23 Engine Diver wall issues
PostPosted: Wed Jul 29, 2015 6:51 pm
just install a couple of L brackets on the floor to keep it from popping out of the C channel...
PostPosted: Thu Jul 30, 2015 4:59 am
go to lowes and get some aluminum L channel and that will solve your problem
PostPosted: Thu Jul 30, 2015 8:07 am
I just did 2 pieces about 3" long on each side.
PostPosted: Thu Jul 30, 2015 8:30 am
Thanks Guys, that is what I was thinking, but wanted to know if anyone else had that problem too. I know there are different sizes of L channel, what size did you guys use and can you post any pictures?
PostPosted: Thu Jul 30, 2015 9:12 am
I just bought 1" x 1" L channel from homedepot and cut it into about 3" long pieces (hack saw works pretty easy). I drilled two holes (for the floor side) and used 1" stainless screws. I did two pieces for each center divider only and have not had any issues at all.
Users browsing this forum: No registered users and 77 guests
