It is currently Fri Oct 23, 2026 8:55 am
 Post subject: 2015 Axis A22 oil change 5.7 Crusader engine
PostPosted: Fri Jul 10, 2015 10:09 pm
Just wondering if anyone has changed the oil yet on this new engine?
And what oil is everyone using? I weight mine pretty heavy for surfing running at 4K rpms
 Post subject: Re: 2015 Axis A22 oil change 5.7 Crusader engine
PostPosted: Fri Jul 10, 2015 10:54 pm
Just had mine changed at the dealer. No clue what oil it is, whatever the manufacturer recommends.
PostPosted: Sat Jul 11, 2015 6:28 am
Rotella 15w40 is what my dealer suggested.
PostPosted: Sun Jul 12, 2015 7:08 pm
I got the rotella 15w40 and a wix filter gonna do it this week looks easy enough
PostPosted: Sun Jul 19, 2015 11:49 am
Well not as easy as I thought oil will not drain out freely after the engine is hot?? Is there a pet cock on the oil pan? Do you have to use suction ?
PostPosted: Mon Jul 20, 2015 5:18 pm
My drain tube isn't long enough to go through the drain plug. I just insert the plastic hose for my vacuum pump into the drain hose and suck the oil out-easy and no mess.
PostPosted: Mon Jul 20, 2015 5:57 pm
PostPosted: Tue Jul 21, 2015 8:19 pm
That's what I ended up doing. Had to buy a vacuum pump, got it at Northern tool for like 60 bones and the reservoir hold 6quarts I think! Was kinda disappointed the drain hose wouldn't go through the rear drain plug though seems like there would be a better design
PostPosted: Wed Jul 22, 2015 1:41 pm
You need to attach a pump to the drain hose and pump it out. Go to home depot and getting a matching set of fittings (it's a standard NPT Thread) that allows you to attach it to something like this:
http://www.amazon.com/Trac-T10060-Fluid ... d+oil+pump
PostPosted: Mon Aug 17, 2015 7:51 pm
Sorry to bring back a dead thread, but is the Wix 51515 oil filter a cross over for the crusader part # 22679 oil filter?
Users browsing this forum: Google Adsense [Bot] and 21 guests
