It is currently Thu Oct 22, 2026 8:35 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Heavy Vibration
PostPosted: Wed Jul 15, 2015 1:51 pm
Just curious if any one else has had a vibration with their axis boat. We have a new 2015 T23 and when in neutral or a very slow idle, there is a vibration that is somewhat intermittent that seems to originate at the back of the boat. I opened the wedge hatch and put my hand on the surf Pipe and it was vibrating heavily. The vibration goes away with more throttle and from what I can see there is no movement or vibrations associated with the engine. I am stumped and don't want to miss any days and take it back to the dealer but also do not want to cause any possible damage.
THanks!
 Post subject: Re: Heavy Vibration
PostPosted: Wed Jul 15, 2015 2:13 pm
Take it to your dealer...it's not normal under no circumstances
PostPosted: Wed Jul 15, 2015 2:16 pm
Definitely take back to the dealer. Missing a weekend now is much better than several down the road.
PostPosted: Fri Jul 17, 2015 11:02 am
I got it to the dealer and they went through it with me and said it was normal. That with the new PCM engines that the way it loads up and dumps with the single port, that its normal. Any others with the PCM 350 in a 2015 have any input? Again only in netural or at very very low speeds can the vibration be heard or felt.
PostPosted: Fri Jul 17, 2015 12:32 pm
Did they actually take it on the water? I would want to be there with them when on the water.
________
PostPosted: Fri Jul 17, 2015 2:10 pm
yea showed them exactly what it was doing on the water and he assumed me it was normal
Also axis carries a vibration a bit more cause of hot the stringers are fused with no space
PostPosted: Fri Jul 17, 2015 8:57 pm
I have the same boat with the same issue. You will get used to it. Sorta
PostPosted: Sat Jul 18, 2015 7:32 am
Same boat, same "feel". Yours seems maybe a little more pronounced than mine; but I agree with your dealer. You can really tell when you have it hooked to a fake-a-lake. The water dump is tremendous.
PostPosted: Sun Jul 19, 2015 4:24 pm
I have a t23 with the 409 there is no vibration like you are talking about, something is loose.
PostPosted: Mon Jul 20, 2015 8:39 am
The 350 has only on port, does the 409 have that as well or dual ports?
Users browsing this forum: Majestic-12 [Bot] and 71 guests
