It is currently Tue Sep 16, 2025 2:08 am
 Post subject: Dual Battery Switch
PostPosted: Tue Dec 27, 2011 4:45 pm
Just wondering what you guys think about the dual battery option. I have an a22 with audio pkg 2 and I'm wondering if I need the extra battery. I also might only install the switch with my single battery so that I can kill the power after each day of use. How hard would the install be if I do it myself. Any info would be great Thanks
 Post subject: Re: Dual Battery Switch
PostPosted: Tue Dec 27, 2011 5:04 pm
It depends on how you use your boat. If you hang out and listen to your stereo for extended periods of time you should definitely add a second battery. It is an easy install (just a tight quarters sitting in the storage locker) - Diagram one is the on I used to hook up the second battery.http://www.perko.com/images/catalog/pdf ... 0(8500INS1).pdf
PostPosted: Wed Dec 28, 2011 7:31 pm
I understand how it works but Im just not sure if this is a task that I should tackle myself. A local dealer said $300 for the install they are not an axis dealer they deal in tige, but they are very good with service.
PostPosted: Wed Dec 28, 2011 9:35 pm
I was a little nervous about it as well, but as long as you double check everything- there's no need to pay 300 for it. Hook engine starter to common, terminal 1 to starter battery, terminal 2 to accessory (stereo) battery. I'd also run your main power for your amps straight from the common lead as well.
Save the extra $$$ for a couple beers after the job!
PostPosted: Wed Dec 28, 2011 9:36 pm
It is a very easy install. I install for a living, dont be intimidated by this one. I still need to install the 2nd batt to my switch.
Gibby
2011 A22 Vandall
PostPosted: Mon Jan 02, 2012 4:53 pm
What brand battery switch comes on from the factor. I think it is blue sea system but I'm not sure. Also I might install a auto charger with the switch what do you guys recommend.
PostPosted: Mon Jan 02, 2012 6:56 pm
Mine has the Blue Sea Systems 9001E - http://bluesea.com/products/9001e.
PostPosted: Mon Jan 02, 2012 8:09 pm
that looks like the one in my 2010 a22
PostPosted: Sun Jan 15, 2012 5:02 pm
What about the ground wires? Tie them together
PostPosted: Mon Jan 16, 2012 9:28 am
Yes run them together.
Gibby
2011 A22 Vandall
Users browsing this forum: No registered users and 96 guests
