It is currently Fri Oct 30, 2026 5:21 am
 Post subject: New t22 questions
PostPosted: Tue Jun 16, 2015 8:43 pm
Hey all I just took delivery of my 15 t22 on Friday. I'm still putting the break in hours before I load it up but non the less i have some questions maybe some can answer. I opted for the Bluetooth feature but have yet to figure out how to hook it up. I got sound pack 2 which i understood comes with Bluetooth. My question is, it built in to the head unit or is it an add on device? If it is an add on where would I find it? Next is the bow light. I had my nav lights in for about an hour. I touched it climbing out in to the trailer at the ramp and burned my leg pretty good. Anyone else notice it to get that hot? I did not get the zero off gps control I went with the standard system. How can I change it from reading rpm vs mph? I have it on rpm and can't figure out how to switch modes. I'm sure there will be more questions in the future. Thanks in advance for any help!!
 Post subject: Re: New t22 questions
PostPosted: Tue Jun 16, 2015 8:59 pm
I can take the first one, so you got the bluetooth option? Or you got sound pack 2 and your assuming sound pack 2 comes with Bluetooth? Cause sound pack 2 does not come with Bluetooth. But if you got the Bluetooth option then u simply turn the head unit to "aux rear in" then turn the bluetooth on on your phone and it should come as "coast" well at least that is what my 2015 is
PostPosted: Tue Jun 16, 2015 10:26 pm
Congrats on the boat.
To switch the cruise from rpm to speed just hold down on the cruise switch for a few seconds and release. You can switch back and forth whenever.
PostPosted: Wed Jun 17, 2015 12:46 pm
as far as the nav light. I've burnt the crap out of my leg from the nav light on the last three boats I've owned... they all got very hot. I still haven't learned my lesson, because I did the same thing this past weekend.
PostPosted: Wed Jun 17, 2015 1:21 pm
your bt password is default 1234 or 1111 something like that
PostPosted: Wed Jun 17, 2015 8:56 pm
You guys are awesome. Bluetooth is working and cruise on mph! What does everyone use for cruise control? Rpm, mph or zero off?
PostPosted: Thu Jun 18, 2015 1:25 am
Always RPM
2012 Axis A20 Down Under
PostPosted: Thu Jun 18, 2015 8:15 am
I use MPH
2018 T22
PostPosted: Thu Jun 18, 2015 8:47 am
i have zero off and to be honest i liked RPM mode better on my old a22.
PostPosted: Thu Jun 18, 2015 9:05 am
I'm confused. If the goal of wakesurfing is to find your ideal weighting and speed and the same with wakeboarding then why would I ever use anything but MPH?
What do I care about RPM being consistent if the goal is consistent speed?
This isn't meant to be an argument or sarcasm but I'm asking as I just don't follow so I am hoping someone would explain and I could learn something.
Thanks
2015 T23
