It is currently Tue Dec 16, 2025 6:58 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2, 3  Next
 Post subject: How to hook up bow sac on 2015 axis T22
PostPosted: Tue Jun 02, 2015 6:58 am
Trying to get some help on knowing which hose goes to which hookup on the bag. I am new to axis and would appreciate any help given.
 Post subject: Re: How to hook up bow sac on 2015 axis T22
PostPosted: Tue Jun 02, 2015 10:23 am
Unhook the y remove it. Turn on front pump and put hose to your ear should be able to tell which hose is Hooked to the pump it will go to one of the ports on the top of the bag. Then trace the other two hoses one will go down through the floor that will be the drain. The other hose will be the vent hook it to the other port on the top of bag. Hope this helps.
14 t22 with sg
PostPosted: Tue Jun 02, 2015 12:09 pm
Yes this does help greatly appreciated
PostPosted: Wed Jun 03, 2015 4:26 am
The fill should have a check valve on it, the drain should go into the floor, and the vent should be the most forward hose.
PostPosted: Wed Jun 03, 2015 12:40 pm
This should help me when I'm playing around with it this weekend, still need to buy sacs though!
PostPosted: Sun Jun 07, 2015 7:52 am
I have 2015 T22. Dealer installed bow sack. The bow space under seats is very tight, my bag pushes up the center cushion when too full. My biggest concern is the top of bag hitting the unfinished fiberglass. The fiberglass has a lot of sharp edges that could easily puncture the bag. Has anyone addressed this or had an issue?
PostPosted: Mon Jun 15, 2015 1:23 pm
I had the same concern..100 hrs later and bow bag never popped or leaked.. but i agree, shame on axis for such a shabby fiberglass job...watch you fingers when installing that bag you will get poked
PostPosted: Mon Jun 15, 2015 8:40 pm
Thanks for starting this thread. I just picked up my 15 t22 on Friday. 3 hours always from being able to fill her up and throw the rope out. I assume the valve in the rear lockers has to do with the plug and play? Did you guys reinforce your engine dividers? I have 750s coming and would like to do any prep work before the bags come in. And to agree with what others stated about the Fiberglass work, they should slow there production line down a tad and finish of the details.
PostPosted: Mon Jun 15, 2015 8:57 pm
No engine wall support with 750
14 t22 with sg
PostPosted: Sat Jun 20, 2015 6:51 am
Did those who installed the bow sac have to buy extra quick connect fittings? I find it kind of messed up that the back came with the fittings installed and not the front.
Users browsing this forum: Majestic-12 [Bot] and 40 guests
