It is currently Sun Nov 01, 2026 12:37 am
 Post subject: ShoreStation Bunk Height for T22 ?
PostPosted: Sun May 31, 2015 9:31 am
I recently purchased a new T22 and am docking it on a 50120 ShoreStation Lift. Typically when landing the boat I like a little bunk resistance to help center the boat. When doing this for the first time I found that the T22 fins actually contacted the cradle. To get around this I need the cradle as deep in the water as possible which leaves the boat floating around in the water and hitting the lift. This is 'okay' short term, but it looks like I have to get longer bunk brackets to get around this ? Has anyone else had a similar issue with the T22 hull? If so, did you buy longer bunk brackets or did you move the bunks closer to the center of the boat ? I tried to get the ShoreStation lift dealer to step up, but I was quickly dismissed as they are very busy this time of year....and they already have my money.
Thoughts ? :roll:
