It is currently Thu Oct 29, 2026 3:29 pm
gibbs114
Post subject: Dual Battery Switch Posted: Tue Dec 27, 2011 4:45 pm |
Joined: Wed Nov 30, 2011 8:08 pm Posts: 770 Location: West Tennessee
Just wondering what you guys think about the dual battery option. I have an a22 with audio pkg 2 and I'm wondering if I need the extra battery. I also might only install the switch with my single battery so that I can kill the power after each day of use. How hard would the install be if I do it myself. Any info would be great Thanks
_________________ Gibbs Malibu 23 LSV
elc
Post subject: Re: Dual Battery Switch Posted: Tue Dec 27, 2011 5:04 pm |
Joined: Tue Apr 27, 2010 11:31 am Posts: 327 Location: Anaheim hills, ca
It depends on how you use your boat. If you hang out and listen to your stereo for extended periods of time you should definitely add a second battery. It is an easy install (just a tight quarters sitting in the storage locker) - Diagram one is the on I used to hook up the second battery. http://www.perko.com/images/catalog/pdf ... 0(8500INS1).pdf
gibbs114
Post subject: Re: Dual Battery Switch Posted: Wed Dec 28, 2011 7:31 pm |
I understand how it works but Im just not sure if this is a task that I should tackle myself. A local dealer said $300 for the install they are not an axis dealer they deal in tige, but they are very good with service.
nastya20
Post subject: Re: Dual Battery Switch Posted: Wed Dec 28, 2011 9:35 pm |
I was a little nervous about it as well, but as long as you double check everything- there's no need to pay 300 for it. Hook engine starter to common, terminal 1 to starter battery, terminal 2 to accessory (stereo) battery. I'd also run your main power for your amps straight from the common lead as well.
Save the extra $$$ for a couple beers after the job!
Gibster786
Post subject: Re: Dual Battery Switch Posted: Wed Dec 28, 2011 9:36 pm |
Joined: Wed Sep 14, 2011 2:15 pm Posts: 165 Location: Virginia Beach, Virginia
It is a very easy install. I install for a living, dont be intimidated by this one. I still need to install the 2nd batt to my switch.
_________________ Gibby 2011 A22 Vandall
gibbs114
Post subject: Re: Dual Battery Switch Posted: Mon Jan 02, 2012 4:53 pm |
What brand battery switch comes on from the factor. I think it is blue sea system but I'm not sure. Also I might install a auto charger with the switch what do you guys recommend.
Dave.Mishchenko
Post subject: Re: Dual Battery Switch Posted: Mon Jan 02, 2012 6:56 pm |
Joined: Fri Aug 20, 2010 5:21 pm Posts: 336 Location: Vancouver
morrisdl
Post subject: Re: Dual Battery Switch Posted: Mon Jan 02, 2012 8:09 pm |
that looks like the one in my 2010 a22
gibbs114
Post subject: Re: Dual Battery Switch Posted: Sun Jan 15, 2012 5:02 pm |
What about the ground wires? Tie them together
Gibster786
Post subject: Re: Dual Battery Switch Posted: Mon Jan 16, 2012 9:28 am |
Yes run them together.
Users browsing this forum: Google [Bot] and 43 guests |
