It is currently Fri Oct 23, 2026 1:58 am
Post new topic Reply to topic  [ 12 posts ]  Go to page Previous  1, 2
 Post subject: Re: Plug N Play Bottleneck
PostPosted: Thu Mar 19, 2015 4:10 am
ThatGuy wrote:
dezul wrote:
I definitely don't have that issue. I do have the issue with the arrow sac not draining all the way.
This is the 2nd time this week I've ready this. What do you do to get it drained? Does it make it difficult to load on the trailer with it partially filled? Do you just pull the seat to check if drained or what?
No issues at all loading it on the trailer. We typically just drain it after we pull it out of the water. The boat is on an incline and that helps drain it.
PostPosted: Fri Mar 20, 2015 12:50 pm
OK, here's the deal. I got in touch with WakeMakers and they cleared some things up.
In 2013 Axis upgraded to 1" fill and drain lines, but a bunch of early boats built in 2013 still had some older components in the ballast system.
This T fitting is one of them. I'm going to try and get a larger fitting, but I also think that I may investigate adding a dedicated drain pump to the plug n play bag in the future. For ~$125 I can get 1200 gph tsunami pumps and really pump some serious water.
I'll update with whatever I do. Thanks y'all.
Users browsing this forum: Google [Bot] and 26 guests
