It is currently Fri Jul 03, 2026 12:10 pm
 Post subject: Adding vent lines to rear pnp???
PostPosted: Tue Feb 24, 2015 12:15 pm
Has anyone added vent lines to the rear pnp? I think I remember a thread about it but can't find it. I have a 14 with the ronix 800s in the lockers. I usually have to purge them every other time we go out. Thanks
 Post subject: Re: Adding vent lines to rear pnp???
PostPosted: Tue Feb 24, 2015 12:42 pm
All you need is a Y and some hose to Y into the hard tank vent. Wake Makers has them. Don't forget 3m marine sealant and clamps.
PostPosted: Tue Feb 24, 2015 12:48 pm
Heres a thread I had in my favorites
http://www.wakeboatowners.com/viewtopic ... 46&p=18164
PostPosted: Tue Feb 24, 2015 12:51 pm
Interesting thread as I've never had this issue with with of my two Axis boats.
PostPosted: Tue Feb 24, 2015 1:18 pm
Thank you.
PostPosted: Tue Feb 24, 2015 4:34 pm
I have looked for a wholesale supplier for those Y fittings. The only Y fittings I found that are good come from Malibu/Axis and they are pretty expensive. Anyone know a good manufacturer of the Y fittings?
PostPosted: Wed Feb 25, 2015 2:39 pm
I just purchased the Y fittings and "screw in / quick release fittings" from Wake Makers for my rear PNP Fly High Bags. I have not installed them yet, but Wake Makers was very helpful in telling me exactly what I need specifically for my 2014 A24. Now I have to figure out which hose is the vent pipe so I cut the correct one!
WakeMakers were also great help with the front bow under seat bag and connections which I did get installed last week.
Wholesale suppliers -- At West Marine, the packaging for one of the same connectors said " Marine East" www.marineeast.com but I do not know if that was the manufacturer or wholesaler. Good Luck
Jim Fuller
Lake Keowee, SC
2014 Axis A24
Boat Name: Who's Next
PostPosted: Thu Feb 26, 2015 12:11 am
Using that rear ballast fitting, wouldnt it be pretty easy for the bag to start draining while surfing? Just curious, like this picture.
PostPosted: Thu Feb 26, 2015 8:45 am
Buy em directly from the manufacturer ....
https://www.flow-rite.com/
PostPosted: Thu Feb 26, 2015 12:23 pm
I found the factory Wye fittings from Axis/Malibu.
www.boardstop.com/product_info.php?products_id=7233
Users browsing this forum: Google [Bot] and 59 guests
