It is currently Fri Oct 30, 2026 5:08 pm
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: T23 Ballast Recommendations
PostPosted: Fri Feb 20, 2015 5:41 pm
admin why would you run the A style open bags in the T23? It's setup the same as the T22 and made to use the 650lb Triangle bag. The 650lb triangle doesnt fill all the way in the T22 so with the added space/storage under the T23 seats it should be able to fully fill up. If you need a little more weight, I would drop some lead bags in.
For 2015, SL has these bags that work with the Axis lineup.
A20
A22 and A24
500lbs
or 750lbs
T22 and T23
PostPosted: Fri Feb 20, 2015 10:15 pm
SteveM, thought the T23 was walk-thru bow with a bow filler cushion and not a true play pen? How does the triangle fit a walk-thru? Seems like the A-shaped sack fits the contour of the bow. I could be wrong though since I haven't been in the T23 yet.
PostPosted: Sat Feb 21, 2015 7:57 am
Ed -- my spray date is 9 March and part of my deal with the dealer includes the front bag... so I want the biggest one of whatever fits up there and works with the T23. :-)
CAN'T WAIT TO BE BACK IN AN AXIS!
PostPosted: Sat Feb 21, 2015 10:22 am
Next stop is Hydrotunes to get that 15" sub installed
PostPosted: Sat Feb 21, 2015 11:22 am
Sorry guys, the T23 is a true playpen setup like the T22. Only the A22/A24 have the true walk through.
PostPosted: Sun Feb 22, 2015 8:42 am
AJ -- come on man.... 15" WOOFA!
PostPosted: Mon Feb 23, 2015 11:13 am
I tasked my shop guy to pull the cushions on the T23. but looking at SteveMs pic I believe the sumo or BFI triangle bags are the ones to use.
PostPosted: Tue Feb 24, 2015 3:11 pm
The triangle is likely the one to use ... it does NOT fill with the T22 but will definately fill with the T23. There'a about 2 to 3 more inches in height on the T23. Adding lead would be a good idea.
PostPosted: Wed Feb 25, 2015 3:17 pm
I just hooked up all of the ballast in my T23. I got all Flyhigh Fat sacks from Bake's marine and they worked out perfect. I ordered a W028-1 1/8 for the bow and 2 W036-1 1/8 for the rears. I would highly recommend these sacks for anyone else debating. I did go with the 1100s for the rear. That is what I had in my A24 and they worked out perfectly!
PostPosted: Sat Feb 28, 2015 5:57 pm
I would like to see the results of that on the water for wake boarding.
