It is currently Thu Jul 02, 2026 6:23 pm
 Post subject: Engine Compartment Support
PostPosted: Wed Jan 07, 2015 1:40 pm
I cannot find an old post about supporting the side walls to the engine compartment
What are you using to support the side walls to the engine compartment so the ballast bags do not push it in? I remember pictures from an old post that looked like a U shaped metal brace that was screwed to the side wall. Where did everyone buy it?
I want to install in on a 2014 A24
Jim
Cumming, GA
Jim Fuller
Lake Keowee, SC
2014 Axis A24
Boat Name: Who's Next
 Post subject: Re: Engine Compartment Support
PostPosted: Wed Jan 07, 2015 1:56 pm
You can buy this from wavemakers - http://www.axiswakeboardboats.com/viewt ... =14&t=2775. Or you can get shelving track from a home improvement store if you want to DIY.
PostPosted: Wed Jan 07, 2015 3:58 pm
Search for "engine divider" and it should pop up.
PostPosted: Wed Jan 07, 2015 5:52 pm
The Wakemakers kit is good and it's already put together for you. I have an A24 with Sumo 900's rear sacks and the divider walls arent reinforced and show no signs of flexing with filled full. Never can be too safe so it's a good, simple mod for peace of mind. When I had my A22 i did reinforce due to using 1100 sacks and the A22 had a more narrow beam than the A24
PostPosted: Wed Jan 07, 2015 6:12 pm
Thanks everyone ... exactly what I was looking for
Jim
Jim Fuller
Lake Keowee, SC
2014 Axis A24
