It is currently Fri Oct 23, 2026 2:46 pm
 Post subject: Re: Fresh Air Exhaust (FAE) on a 2014 T22
PostPosted: Fri Sep 26, 2014 12:00 pm
shawndoggy@gmail.com wrote:
Having one it's hard to consider NOT having one on the next boat.
Very true.
PostPosted: Fri Sep 26, 2014 12:02 pm
How hard is it to lower/raise the wedge with the FAE?
PostPosted: Fri Sep 26, 2014 11:03 pm
Haha, I see that Larry is now using the new mounting bracket mounted to the wedge bracket that he prototyped with my boat. I do have to say I am disappointed that I can no longer lower the wedge via the trap door. I just can't get a hand on both pins at once. It is still possible to pull the wedge back up through the door.
PostPosted: Fri Sep 26, 2014 11:10 pm
Does that mount require any drilling into the wedge mount? Like Walter I made my own bracket that attaches to the wedge mount - worse thing I've even had to drill through.
I also recently replaced the hose clamps that came with my kit with a T-bolt type clamp. Fixed the slipping problem I was experiencing.
PostPosted: Fri Sep 26, 2014 11:24 pm
Nope, that mount basically clamps onto the top plate of the wedge bracket. I didn't have to drill anything for my install. I'd post pictures but the ones above cover it pretty well. Maybe I can get a better angle on the bracket for you though.
PostPosted: Sat Sep 27, 2014 7:43 am
Ya I trashed a few drill bits on mine
Users browsing this forum: Majestic-12 [Bot] and 18 guests
