It is currently Sat Sep 13, 2025 6:50 pm
 Post subject: Re: A22 rear ballast
PostPosted: Fri Sep 12, 2014 11:01 am
This is the one our guys ordered for walter... http://www.boardstop.com/product_info.p ... ts_id=7113
It is a W715 we just had them make them in red.
PostPosted: Fri Sep 12, 2014 12:31 pm
That bag fit perfect ED! Now I need a prop lol, any group buys on a 2315
PostPosted: Fri Sep 12, 2014 1:29 pm
I would possibly be in on a group buy for a 2315 as well.
Joey
2012 A22
PostPosted: Fri Sep 12, 2014 1:31 pm
Me Too.
2014 Axis T22
PostPosted: Sun Sep 14, 2014 8:51 pm
I was extremely happy with my 2315 - It made the difference - I have a 2014 A22 - Running 750s in the rear lockers - 920 up front - Center Filled - 650 sitting on the Stadium seat pulled out about 18" (Stays there real good) - Wedge Down for me (200 lb rider), up for the wife (130 lbs) - When I get 8-10 adults in the boat (Remove the 650 Bag) and have the Wedge down it takes a little longer to get rolling but that Prop works well - Forget about going faster than 32 mph after you install it though..
2014 A22 White/The Ghost
2015 A22 Yellow/Black/The Bee
PostPosted: Mon Sep 15, 2014 6:55 am
What kind of gallons per hour do you burn?
What are the RPMs at surf speeds loaded like you have mentioned?
PostPosted: Mon Sep 15, 2014 2:38 pm
Depending on my passenger count, mine surfs between 3100-3500 rpms with the 2315 and full bastast and wedge.
PostPosted: Tue Sep 16, 2014 8:03 am
Thanks, I am typically around 3000 to 3200 with a full boat, same conditions and the 1235 (Hi Altitude). We've measured it at 4.6 GPH, so I assume yours might be a little higher GPH. Top end around 42/43 which is nice because we do enjoy barefooting (yet to be tried but soon!).
PostPosted: Tue Sep 16, 2014 8:14 pm
I am Typically running around 3000-3200 also - We went another step furthur - Our Boat Surfs best from 1/2 Tank - to 3/4 Tank - We took a Surfing Lesson On Lake Martin this summer (Trying to pull off a SuvIt) - He said the Same thing about the Gas Load -Rides for Singleton Marine - I go through about 13-Gallons on a Normal Day of surfing (Full Day) - We Ride about 9.5 - 10.0 - Depending on the weight in the Boat and the Head wind - More weight faster Speed - Head wind slower Speed.
PostPosted: Mon Sep 22, 2014 1:03 pm
Hey Ed, thanks for the link! I'm thinking of getting the custom bow for the 2015 A22s. Any feedback on those? http://www.boardstop.com/product_info.p ... ts_id=7110
I'm thinking two of the W715 Rear Sacs, and the new custom bow sac.
Axis A22 2015
