|  | It is currently Fri Oct 31, 2025 3:08 am
		|     | Page 1 of 1
 | [ 3 posts ] |  |
			| Author | Message |
			| Gibster786 |
					|  Post subject: Another winterization  Posted:  Wed Nov 02, 2011 8:37 am  |  |
					| Team Axis |  Joined: Wed Sep 14, 2011 2:15 pm
					| I have searched the malibu forums for a good write up on winterization. Can one of you guys that are a member over there help me out.
 I dont know if my other post was read but do any of you recommend shrink wrapping the boat for the winter?
 Also I need to goo info on how to winterize ballast tanks in our boats.
 Gibby
 2011 A22 Vandall
			| Top |   |
			| rpinto |
					|  Post subject: Re: Another winterization  Posted:  Wed Nov 02, 2011 1:09 pm  |  |
					| Axis Owner |  Joined: Mon Jul 19, 2010 1:27 pm
					| I just finished up winterizing my A22 last weekend. I can't advise you on Shrink wrapping your boat as mine is stored in a barn but sounds like it wouldn't hurt to do. For the ballast I just made sure the hard tanks and lines are empty and also removed all of the plug and play bags from the boat.
			| Top |   |
			| Armada |
					|  Post subject: Re: Another winterization  Posted:  Wed Nov 02, 2011 6:35 pm  |  |
					| For the shrink: does for boat will be inside if so what will be the temp?, or outside protected?For the ballast: you need to put antifreeze in the ballast and run the pumps tp make sure there antifreeze in the system. The easiest way to add antifreeze I found is to put it directly in the lines at the back of the boat in the engine compartment.
			| Top |   |
		|     | Page 1 of 1
 | [ 3 posts ] |  |
		| Who is online |
		| Users browsing this forum: No registered users and 118 guests |
	|  | You cannot post new topics in this forum You cannot reply to topics in this forum
