It is currently Tue Nov 04, 2025 9:12 pm
 Post subject: Re: Under Helm Flutter
PostPosted: Wed Jul 30, 2014 10:51 pm
away wrote:
When I give heavy throttle like pulling a person out of the water I have a slight flutter noise that comes from under the helm or steering wheel. (like rudder flutter-if you will) I was wondering if this is common or something needs looked at. I asked my dealer and they said it is just cable operated so there shouldn't be any sort of sound or vibration etc.. I then called the tech service with the manufacturer of these steering systems and he said if anything was loose at the rudder or noise in the engine bay that the cable would act like a speaker wire and amplify the noise at the helm. I have checked the bolts at the rudder and found them a little loose so I tightened these and the sound decreased significantly but it is still slightly there.
After speed is reached the sound goes away so it is just as the boat is accelerating.
Just wondering if other boats hear this or should I even be concerned about it.
Thanks in advance
any updates?
PostPosted: Fri Aug 01, 2014 10:37 am
I have the same issue - typically when I am throttling to get my boat on the trailer. It seemed to just start happening more this year (2012 A22). I have noticed my steering wheel has slight play in it so I was going to remove the wheel cap and see if something needs to be tightened in there. I plan on mentioning it to the dealing next time i'm in, but I did not have high hopes of them know what it was.
PostPosted: Fri Aug 01, 2014 10:43 am
I don't know if this helps anyone but when we took delivery, we noticed a thumping or rubbing noise. It was only when we pulled up a rider or hit wakes while turning. Turned out to be the cables from the helm to the motor compartment. Dealer wrapped them with a foam insulating material and viola no more noise.
PostPosted: Fri Aug 22, 2014 2:31 pm
my steering started with play in it as well then tightened up and turned out to be rudder box and rudder.
I would read up on the water seal rudder box.. lots of problems with it.. its a nice $700 gotcha.
not sure what causes it but I will see how long my second one lasts. I asked for a grease capable unit but time did not allow. Replaced and like new.
here is a video of my problem. https://www.youtube.com/watch?v=ZuIXUlAi258
2017 A22
2011 Vandall
