It is currently Sat Oct 31, 2026 9:44 am
 Post subject: Show me your Axis wake pics....
PostPosted: Tue Oct 25, 2011 5:42 pm
stock, slammed, whatever....
here is my A22 with 4000, no wedge, 2 adults and 2 toddlers, 3/4 tank, 78' I think i was riding at 24.8 (right ed?) in somewhere between 6'-14' depth.
 Post subject: Re: Show me your Axis wake pics....
PostPosted: Tue Oct 25, 2011 7:59 pm
about 3000lbs with wedge down in the a20; 21.5mph, 3/4 tank, and driver only in the pic
PostPosted: Tue Oct 25, 2011 9:34 pm
Crappy iPhone pic but ohh well! We are running 4400 lbs, wedge down, 8 people, full tank, and 23.6 mph
PostPosted: Wed Oct 26, 2011 8:18 am
2011 A22. Raptor. Wedge. Factory 900. 1000lb bags in the rear lockers. Front 900lb pnp bag and 1000lb bow triange. 3 people @ 24mph. (~4800lbs + wedge + people).
PostPosted: Wed Oct 26, 2011 8:20 am
:D
PostPosted: Wed Oct 26, 2011 11:16 am
you guys make me sick... im pouting! lol. Screw it im over the idea of pnp 400s in the rear. im at least doing the 750s. if i hook them up the factory way which section fills first? factory tank or bag? i want to be able to give beginner riders something less. if i want that do i need to hook it up johnny and eds way??
Gibby
2011 A22 Vandall
PostPosted: Wed Oct 26, 2011 6:56 pm
Here's how I have mine
viewtopic.php?f=14&t=137
PostPosted: Wed Oct 26, 2011 10:03 pm
gibster, with whatever bag you go to, you can hook them up the 'factory' way like in walters (how to hook up your plug n play) write ups, they are very good. You will fill your hard tanks first THROUGH the bag. Water will be pumped into the bag and drain into the hard tank. It should only take a few minutes to fill the hard tanks, once you see a little bit of water staying in the bag, then you know you have the hard tanks full. Either way you hook them up, you will be able to fill your tank/sack to any level to accommodate any level rider. Factory way is easier because it requires less cutting, less materials (clamps and valves)...
PostPosted: Wed Oct 26, 2011 10:14 pm
one negative with the "factory" hook up. The vent line is still coming out of the hard tank, so getting the pnp sack full without air is not a hands free operation. You may have to unscrew the 2nd plug on top of the sack to let the air vent. Or you can put a spring loaded vent on it so that you can just push the spring down to vent (just like fat sacks).
Are some of you guys adding a vent hose to the sack and capping off the hard tank vent hose?
PostPosted: Thu Oct 27, 2011 7:30 pm
Here's another. 750's in rear, hard tanks full, wedge down, and axis front sac. Just the driver on the boat
