It is currently Tue Oct 20, 2026 7:34 pm
Ferral
Post subject: Re: Ballast Questions - Need some opinions Posted: Wed Aug 13, 2014 7:45 pm |
Brandon, there are 3 different "stock" props that could be on your boat, as that's how many options the factory offers. Just take a look at the prop hub and the model or dimensions should be stamped there.
Brandon161
Post subject: Re: Ballast Questions - Need some opinions Posted: Wed Aug 13, 2014 8:40 pm |
| Boater |
I looked at my prop. This is what was it says..... 13.5x16xL 1 1/8" & 537. Will this prop be a keeper for my setup?
get_sum
Post subject: Re: Ballast Questions - Need some opinions Posted: Thu Aug 14, 2014 7:10 am |
Joined: Fri Aug 17, 2012 1:18 pm Posts: 435 Location: OKC
No. The 537 is a pretty weak prop torque wise. I would at least step up to a 1235 or even bigger 2315. I have the 2315 and have yet to find enough weight this thing wouldn't pull out of the water. However, it's top speed is about 38 mph now. Cruising is good at about 24-28 mph.
Users browsing this forum: Google [Bot] and 47 guests |
