It is currently Tue Nov 04, 2025 7:37 pm
Post new topic Reply to topic  [ 93 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10  Next
 Post subject: Re: A24 1st weekend speed control isssue
PostPosted: Wed Aug 06, 2014 9:16 pm
New tach just arrived. Heading out to the dealer tomorrow to pick it up. Will install tomorrow evening. Anyone have a tip on recalibrating the surf gate?
PostPosted: Wed Aug 06, 2014 11:30 pm
New tach fixed mine. Perfect now.
PostPosted: Thu Aug 07, 2014 3:54 am
Go into the settings and run the "Recalibrate surf gate" setting. It should fix it. Honestly your dealer should do it.
PostPosted: Thu Aug 07, 2014 6:32 am
They would in a heartbeat but I am not pulling my boat out there. Thanks dezul
PostPosted: Mon Aug 01, 2016 5:36 pm
I'm having the same cruise control issue on a 2014 A20, attached is a picture of the tac label.
I called Malibu support and they said the tac issue was fixed on the 2013 models.
PostPosted: Mon Aug 01, 2016 6:11 pm
Rev B has the speed control issues. Lol. Good luck getting them to give you the right one. Hopefully it doesn't cost you to much out of pocket. Also, let me know if we can help.
PostPosted: Fri Oct 13, 2017 4:18 pm
I'm having the speed control issues on my 2014 A20. Big surging, worst at surfing speeds.
I will check the gauge to see what the sticker says tomorrow.
I'm definitely out of warranty, but do you guys know if Malibu will make this one right on their end if I have Rev B?
2014 Axis A20 Surf Gate
PostPosted: Mon Oct 16, 2017 5:27 pm
Well, Malibu tells me this is the most current unit.
PostPosted: Mon Oct 16, 2017 5:46 pm
I as well got told forums are all lies when my stringer popped loose, he ate his words days later when he realized that it did pop, and i have since started using a different and better dealer and he no longer sells axis/malibu
PostPosted: Fri Oct 20, 2017 7:24 am
Has anybody else had to replace their speedometer on a '13 or '14 Axis?
