ac88926 wrote:
Best advise is to just do it.  Once you try it once and realized how easy the falls are youll want to go wake to wake with it.  Keep your egde to the top of the wake and pop first.  Also, you dont need a super hard cut into the wake.  Just steady with that progresive edge.  I think you're overthinking it.  I do this a lot. Youll be good to go after that first attempt.
I typically load the line pretty hard when I do my normal wake to wake jumps. The only differnce I see from the video on load that I don't currently do is have a more straight up stance when loading the line. I normally have a good seated position when loading the line. The gf complains about how much I pull the boat on my loads. I am 230 lbs with a lot of upper body strength. I feel like I can do the one wake backroll attempt easier than I can do the air backroll. I am going to try a couple of load and releases though to see if I get some air off of it before I try anything though.
