larrybuilds wrote:
This is the 4th ski/ wakeboard boat I have owned in the last 30 years, including a Malibu for 18 years.  This is the first time I have had a problem like this.
Larry,
Are you talking about the transom pad or the interior as a whole...?
We keep our boat in storage and pull it out and put it straight into the water.  During that time, (about 5 minutes) the seats (light Gray)  get extremely hot.  They get so hot that those boarding from the front (barefooted of course) have to step on a towel.  This has been the case with any boat we have owned since the temps here in Alabama during the summer get pretty hot.  I will have to say that the transom pad also gets pretty hot as well.(especially when its not wet).  You also mentioned the step down pad between the cup holders.... Ours gets hot here in Alabama because the temps are usually 90-100+  As I said earlier, We deal with it cause its hot and have gotten use to it.  Still not sure how you are boarding the boat though.... If you board when its in the water the transom should be wet.  Not trying to give you a "Psychiatric Diagnosis" but trying to help out an Axis owner.
