It is currently Sat Sep 05, 2026 4:17 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Ballast question
PostPosted: Mon Jul 14, 2014 10:25 am
I have had these same bars a bit longer and they are starting to bend. Not sure how I am going to fix yet...
PostPosted: Mon Jul 14, 2014 10:29 am
Maybe if you mount the bars on the opposite side it might make them more rigid???? I mean same side of the divider, just mount the bars the other way. Where the channel part is facing the motor.
PostPosted: Mon Jul 14, 2014 10:35 am
Mine are still holding up great. No issues at all.
 Post subject: Ballast question
PostPosted: Mon Jul 14, 2014 11:44 am
I have done something very similar to my rear dividers. I have the sumo 900s in the rear and the dividers are holding up nicely. I sort of need to put one or two more screws in the bottom track as it has popped free once or twice before. I just got finished this morning taking out the 2 rear piranha pumps. I have 2 rule 1100gph pumps coming with new switches, lines, and a tee fitting. I also have 2 new tsunami pumps with 1-1/8" lines for the drains. No more gravity draining from bag to tank. This way I'll have separate pumps for each rear tank and bag and separate pumps for the front tank and the front bag.
I can lie, I am a bit nervous drilling a new hole in the sides of my boat, but I well. I will plan it out and it should come out
Ok.
