It is currently Tue Nov 04, 2025 12:46 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Ballast question
PostPosted: Tue Mar 25, 2014 6:42 pm
Yep. They are in the shelving section of home depot. Look for the shorter black bars. I had to cut mine down a little to get it to fit the way I installed it. I repainted the cut end to prevent corrosion.
PostPosted: Tue Mar 25, 2014 7:31 pm
Looks familiar :grin:
PostPosted: Tue Mar 25, 2014 7:33 pm
I would have found your thread but it was easier to post pictures myself.
PostPosted: Tue Mar 25, 2014 7:53 pm
no worries - you did a nicer job.
PostPosted: Tue Mar 25, 2014 10:08 pm
thanks for the info definitely going to be doing this as my first project once I can finally unwrap my boat.
PostPosted: Thu Mar 27, 2014 2:51 pm
Question for you guys who have used all sizes of ballast. I'm trying to decide between the 750's or 1100's. I'm an intermediate wakeboarder and new to the wake surfing. I want a huge surf wave but also want a good wake where it's not to big for my experience level. Which one should I get?
 Post subject: Ballast question
PostPosted: Thu Mar 27, 2014 10:16 pm
First off I'm assuming you have the 330hp motor, but if you have more power the answer could differ. The guys that want a really big wave go with the 1100s or the sumo 900s. But for wakeboarding, you probably won't be able to plane with that much weight all the way in the back. 750s are enough to give you a really big wakeboard wake, but you can always get the bigger bags for surfing and not fill all the way.
PostPosted: Fri Mar 28, 2014 6:03 am
You assumed right. I only have the 330 and a 1235 prop. With buying either the 750's or 1100's, I'm also getting the triangle bow sac to put on top of the seats.
PostPosted: Fri Mar 28, 2014 6:06 am
do you need an extra pump for the extra front tank? how difficult is it to wire into the dash switch. is this easy enuf to do at home, or take to the dealer?
Chris
Axis A20 2014 Surfgate
PostPosted: Mon Jul 14, 2014 9:30 am
Dezul, how is the reinforcement holding up? I just picked up the 1100's and need to do this. Would you do anything different now that you have used it for a few months?
Users browsing this forum: No registered users and 88 guests
