It is currently Mon Dec 08, 2025 9:53 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Any Pet Peeves with your axis.
PostPosted: Fri May 18, 2012 10:49 pm
My 2010 came with stainless cupholders also.
PostPosted: Sat May 19, 2012 7:50 am
I just looked at the configurator, it is an option now.
PostPosted: Wed Jun 11, 2014 10:37 pm
The tower mirror should have a quick release for folding down. More room for front arrow sack to completely fill up. Screws on walk through window keep loosening on their own. Prolly fix that with a little locktite. Vinyl scratches too easy. Trailer brakes squeak with only like 100 miles on them tops. That's about it for me. Everything else is pretty sweet.
PostPosted: Thu Jun 12, 2014 6:43 am
The loose screws and bolts is a pet peeve of mine...fixed with loctite though.
On the A20, you can't fold down the tower arms without moving the drivers seat all the way forward and the passenger side arm rests on a seat cushion. Pretty sure there is no issue with drivers seat on A22 though.
Cruise control is quite glitchy, you have to damn near come to a complete stop after you turn it off or else it acts like it is still on. I want to be able to just hit the switch to turn cruise off and continue going, not have to stop and then start again.
PostPosted: Thu Jun 12, 2014 7:46 am
FRONT POP UP CLEATS !!!!
PostPosted: Thu Jun 12, 2014 7:51 am
Tower folding on the v2 tower. Side supports should be on inside of tower so they can be folded down one at a time. Currently you have to loosen both of the supports lift the tower and one person grabs one and person lifting tower has to grab the other one.
Why can't the tower be self supporting when folded? There needs to be a stop built into it so it sits just off of the vinyl. I understand the tower itself may be too heavy and I would be OK with still using a couple 5 gal buckets and life vests but the side supports are light enough where I think they should come down half way and stop on their own.
PostPosted: Thu Jun 12, 2014 8:06 am
Wow. All very good ideas indeed.
I really wish the side seats had some sort of hinge on them where you could lift them up kind of like the chillax seat. I hate lifting the seat all the way out and moving it to get what I want then having to mess with getting it to fit back in just right. I am paranoid that someone will not put it back right (to where it is not all the way down) and then sit on it and mess something up.
We had a Ski Nautique for 20+ years and never had any issues with the vinly. Something tells me that I am not going to be so lucky with the Axis.
For those with plastic cup holders take some electrical tape and run around the outside of the holder once or twice then put it back in. Makes a snug fit and they will not blow out, and you never see the tape.
PostPosted: Thu Jun 12, 2014 6:47 pm
I built a bracket that screws into the top of the ski pilon. It supports the tower so it doesn't fold down on to the seats. (forgot about that stupid design since I fixed it myself).
PostPosted: Fri Jun 13, 2014 6:44 am
Yes yes yes, FRONT POPUP CLEATS!!!!!! Please!!!!
PostPosted: Fri Jun 13, 2014 7:06 am
One more vote for front pop up cleats!!!
Users browsing this forum: Google [Bot] and 55 guests
