It is currently Sat Sep 26, 2026 1:00 pm
 Post subject: Re: bluetooth adapter
PostPosted: Thu Jun 05, 2014 6:19 pm
I did this on my 2012 and it was really easy. I just had to move one wire from the ignition switch to the unused ACC switch.
PostPosted: Mon Jun 09, 2014 7:53 am
I wonder if doing the bypass would affect the auto sound feature. When I throttle up or down the stereo volume automatically adjusts for engine noise it works great!.. I wouldnt think it would bc its just a 12v hot feed but im not too sure how it adjusts.
PostPosted: Mon Jun 09, 2014 9:21 am
Axis_UK wrote:
This thing is awesome. Only took a couple of minutes to wire it up and it works great. Great find.
PostPosted: Mon Jun 09, 2014 11:13 am
Anyone got any pics of instalation?
I would love to do this also!!
PostPosted: Mon Jun 09, 2014 12:19 pm
I am running the Sony head unit from factory.
Black wire from Bluetooth to black wire. (Ground)
Red wire from Bluetooth to Blue wire from head unit. (Power)
Plug the two RCA jacks to the AUX jacks from head unit and you are done.
Hope this helps.
PostPosted: Fri Jun 13, 2014 8:29 am
Installed last night......so easy.....works great!!! At the marina in the slip it would play from six boats down......more like 60-70 ft away!!
PostPosted: Tue May 19, 2015 11:40 am
Does anyone have experience in installing this module AND Satellite radio? Both require AUX in's but there is only one.
2013 axis vandall, green metallic and white, plug and play... RIDE OR DIE!!!!!!!
PostPosted: Thu May 21, 2015 4:01 pm
ok, Ill reply to myself in case someone else is interested. There is a corded dual AV input that enters the head deck in the top left corner just beside the sub out. Connect this then all you have to do is source some power for the module. I wired mine to the ACC switch so you dont have to re-connect if you stop the engine from running. Crimp a spade connector for the power to insert onto one of the open prongs on the ACC switch and wire the neg into the neg for the head deck. Whole process takes maybe an hour and works perfect from over 50' away. Highly recommend. In the end you can run sat radio and bluetooth if you have the right modules.
PostPosted: Thu Apr 14, 2016 6:19 pm
Trying to figure out where to mount my Wetsounds Bluetooth adapter. My WS 420 is mounted under the radio with some aluminum brackets but not sure how to make it work with the Bluetooth piece. Would someone mind describing where they have mounted theirs or even posting some pictures? I have a 2010 axis A22. Thanks
PostPosted: Thu Apr 14, 2016 7:57 pm
I just zip ties mine behind the dash area.. I have an exile one l...
Users browsing this forum: No registered users and 57 guests
