It is currently Tue Sep 16, 2025 2:11 pm
[ 3 posts ] |
Author |
kx250frider617
Post subject: impeller pump leaking Posted: Sat Jun 07, 2014 7:00 pm |
Team Axis |
We just brought home a new to us a22 with LS3. Anyway, it has a fresh water flush. I hooked up the garden hose and it blew off a coolant hose off the raw water impeller pump. Anyway, I hooked everything back up and started the engine and noticed the impeller pump is leaking from what looks like to be the cover plate. I tightened the hoses to the pump already.
Is there a seal between the pump housing and the cover plate for the impeller? It drips water quite a bit.
Top |
Walter
Post subject: Re: impeller pump leaking Posted: Sun Jun 08, 2014 7:43 am |
Team Axis |
There is a thin foam gasket, probably have to buy an impeller kit to get it though, they're not much and since you just bought it used may be a good idea to change it anyway
Top |
kingranch
Post subject: Re: impeller pump leaking Posted: Sun Jun 08, 2014 7:38 pm |
Newbie |
Yea there's a foam gasket and like 4 small bolts Take it off and If u haven't replaced the impeller in the last season then do it too
It's cheap insurance for that pricey motor
Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 63 guests |
