It is currently Sun Sep 14, 2025 9:09 am
 Post subject: Does your boat have a "whine"
PostPosted: Thu Jun 05, 2014 3:08 pm
My boat has a high pitched "whine". It may be from the engine or vdrive. I have since installed a 2315 ACME prop and the "whine" is much more profound. The more RPM's the louder the whine is. Are all the Axis boats like this? Thanks for any info.
 Post subject: Re: Does your boat have a "whine"
PostPosted: Thu Jun 05, 2014 3:29 pm
Yes mine does, it probably follows your rpm's. The 2315 usually runs the engine at higher rpm's so the whine is more pronounced. I always just assumed like you it was engine or v drive noise.
PostPosted: Thu Jun 05, 2014 9:52 pm
Mine does. 330 with high altitude.
2018 T22
PostPosted: Fri Jun 06, 2014 10:15 am
Same here with 5 blade 335
PostPosted: Fri Jun 06, 2014 10:44 am
The whine is just the gears in the transmission, they all have a little noise, mine is noisy in reverse but not forward
PostPosted: Fri Jun 06, 2014 10:51 am
It should sound like a jet engine whine. Or at least that is what I compare it to.
PostPosted: Fri Jun 06, 2014 11:02 am
Same here noisy in reverse not so much in drive. But on the test drive it had the 5 blade OJ prop and that thing was loud. Put the 1235 on there and its quiet now.
PostPosted: Fri Jun 06, 2014 1:35 pm
A couple years ago we did a group buy on the 5 blade and everyone said the opposite, the 1235 was much noisier than the 5 blade and the 5 blade has less vibration. I liked the 5 blade in that aspect but I like the 1235 because it pulls better
PostPosted: Fri Jun 06, 2014 3:41 pm
I noticed that in my boat last weekend, but soon realized that the whining was coming from everyone because we were about to run out of beer.
Users browsing this forum: No registered users and 99 guests
