It is currently Mon Oct 19, 2026 12:51 pm
 Post subject: 2014 A22 cruise control
PostPosted: Thu Jun 05, 2014 5:55 pm
It seem I can't get my cruise control to work and my dealer dose not how to use it. It seem like its a simple system to use. Is there a trick for it to work?
 Post subject: Re: 2014 A22 cruise control
PostPosted: Thu Jun 05, 2014 8:08 pm
I could be wrong but I am pretty sure that you flick the cruise toggle down and on the display it should show 2 speeds. One is your actual speed and the other is your set speed. Use the "set point" toggle to adjust your set speed. once you got it wear you want it you accelerate the boat past your set speed. You should hear a beep that indicates that it is engaged, then it should take over for you. That is how it works on my 2014 a20
PostPosted: Thu Jun 05, 2014 8:22 pm
Thanks I will give that a try.
PostPosted: Thu Jun 05, 2014 9:50 pm
Do not pull back on the throttle. It will cause the speed control to disenguage. Hammer the throttle and leave it. If the rider falls, then pull back.
PostPosted: Thu Jun 05, 2014 10:14 pm
You might try PM'ing DatTexasBoy. He has a 2014 and has had issues with it. I know he's had to use engine rpm (vs mph) to dial in on it but don't recall if there was a fix from Axis yet.
PostPosted: Fri Jun 06, 2014 9:50 pm
The green light comes on the dash when you are engaged, mine was off by 3mph until I got the new gauge installed I had to overshoot to compensate.
PostPosted: Tue Aug 26, 2014 10:25 pm
Mcmiller - what new gauge? We have a 2014 A22 and find the cruise to vary up to 3 mph. That's too much variability and I'd like to fix it if there is a way.
PJ
2014 Axis A22
PostPosted: Tue Aug 26, 2014 10:55 pm
Dealer put in a whole new Tach. My holds speed perfect now.
PostPosted: Wed Aug 27, 2014 1:18 am
+1
I would make a bet that every single 2014 Axis made has or had a defective gauge/tach, causing cruise control issues. Just my opinion.
May want to read this over
viewtopic.php?f=14&t=2279
PostPosted: Wed Aug 27, 2014 1:26 am
it will be very interesting to see if they have fixed this on the 2015 models? anyone out there with a 2015 model yet and has tested this at all? feedback would be very useful. I will check when i get mine in the middle to end of October
2015 Axis A22
Liquid Force Edition
409HP Engine Upgrade
And a few other options!
Users browsing this forum: No registered users and 65 guests
